Megane 1.5dci stalling intermittently
- Currently Drives:: Renault sport 175 dci
It's 08 reg runs brilliantly but cuts out intermittently with electronic fault comes up fault codes 2096 400 1669 come up
Re: Megane 1.5dci stalling intermittently
I can't find the codes 2096 or 1669 in the manual. For the existing codes please refer to this book:
https://www.dropbox.com/sh/355lr8566hrz ... 1.pdf?dl=0
The generic code readers usually return codes in the format P####, which can be translated into the notation of Renault as listed in the above manual book. Remove 'P' for the DTC notation, then search the manual. A universal code reader elm327 is about a fiver on eBay. It's an interface only used together with a laptop or Android mobile phone. It will show the said P#### codes.
Regarding the electronic fault - check the cover on the headlight access hatch on the front left wheel arch cover. If missing, then the PSU (fuse box) under the bonnet may be damaged.
Users browsing this forum: No registered users and 65 guests
