Megane 1.6 16v 54 plate not starting
I have just bought a Megane 1.6 16v and it will not start I have got check injection and stop light, i have checked very little so far, any watchouts with these? Have lots of experience of the F4R in clio 172/182 but not much with these.
- Oliver
Re: Megane 1.6 16v 54 plate not starting
Check the crank sensor and the battery.....
best regards
Oliver
Oliver
Oliver wrote:Check the crank sensor and the battery.....
Had it on leads from mt passat cc so battery fine havent had crank sensor off yet is it on top of bell housing?
- Oliver
On top of the gearbox, just below the thermostat-housing.
https://translate.google.de/translate?s ... edit-text=
(google auto translate)
original: https://scriptkiller.de/de/a11/renault_m ... _ot-geber/
Sensor:
https://i.ebayimg.com/images/g/kXoAAOSwT ... -l1600.jpg
Sensor:
best regards
Oliver
Oliver
Injection + Stop lights mean a critical fault detected by the ECU. It may not be actually a critical fault, but some sensor malfunctioning. In any case, get an OBD reader and see what the ECU reports. ELM327 readers are cheap on eBay (a fiver or so) p!us you need some software for the phone or laptop. I tried Scan master for Windows and Torque for Android. In order to access the ECU while the engine is off, press and hold Start for 5 seconds while not touching any pedals.
Tried the tdc sensor no joy though just keeps cranking doesnt sound like its getting any fuel tbh any know faults/tips?
Users browsing this forum: Bing [Bot], Google [Bot] and 71 guests
