Removing fuel gauge?
- Currently Drives:: Megane II Dynamique 1.4 VVT 2004
I've decided to try and sell my Megane for spares or repair because of electrical faults.It's got a full tank of petrol in it though.I thought I might be able to get at the tank through the fuel gauge(or is it the pump) under the back seat.Does the black ring around it just unscrew?
- q292u
- Global moderator
Re: Removing fuel gauge?
If it's anything like my old Micra, the fuel sender/pipes/float thingy unscrews if you tap it with a hammer and screwdriver. Carefully. Anti-clockwise.
There's probably a proper tool for this, which we can't buy.
That's what I thought.Was wondering if a bit of GENTLE heat from a hot airgun might help free it.Obviously not a blow torch though! Lol.
- q292u
- Global moderator
The way I see it,it won't be any worse than my motorbike fuel tank sitting above a hot engine.If I'm still around I'll let you know if I was wrong!
So I took the safer option and poured a kettle of boiling water around the ring.I don't know if it made any difference as it still took quite a hammering to get it to turn but I'm in now and the tank is full to the brim.
- q292u
- Global moderator
Result! Brute Force and Ignorance wins again!
Users browsing this forum: Bing [Bot] and 69 guests
