Hi There.Got a problem with outer joints on the Arm can I replace the Joints or do I have to replace the arms complete.
2003 Privilege 1600 16v
grizzly14.
Lower Suspension Arm.
Re: Lower Suspension Arm.
I believe you can replace the ball joint BUT will need a machine press to get them out/put new ones in properly. Must easier and better in the long run to replace the whole arm.
Seem to recall others who just replaced the ball joint finding it didn't sit correctly or even split the arm where pressed in.
It's not a difficult job, took me around 3 hours first time.
Users browsing this forum: Bing [Bot] and 67 guests
