No power to window, corrosion inside door plug socket (not the usual)
Posted: Sun Jul 17, 2016 10:34 am
by Bigsy
Thought I had the usual window module trouble but finally tracked it dow to this: https://imgur.com/a/R2KMA
As you can see one of the pins is completely corroded off, anyone know the easiest way of fixing this?
Thanks.
Re: No power to window, corrosion inside door plug socket (not the usual)
Posted: Sun Jul 17, 2016 5:02 pm
by chloemae12
I have a 2000 plate x reg megane. My electric window on. The drivers side front is not working it is clicking as i press the button. But wont open at all all power going to it but nothing at all will happen any ideas please
Posted: Wed Jul 20, 2016 8:02 pm
by cliopapa172
Chloemae12. It's the window control module or temic unit. You can now buy new replacement ones off eBay for around £25 with a two year guarantee and you will need to find someone with the patience to strip down the door panel to replace it or spend a fortune at your local dealers,(not recommended!).
Posted: Wed Jul 20, 2016 10:28 pm
by tanto12
cut one off at the breakers yard leaving enough wire so you can cut yours off and put the new one on
Posted: Sat Jul 30, 2016 3:17 pm
by purlin
I had the same problem, just one pin corroded. I was able to clean it up sufficiently well enough for it to work using wd40, fine needle files and fine emery tape. Its a bit fiddly but worth a go. Failing that do as tanto12 suggested get one from a breakers yard and solder it in.
