Thought I had the usual window module trouble but finally tracked it dow to this: https://imgur.com/a/R2KMA
As you can see one of the pins is completely corroded off, anyone know the easiest way of fixing this?
Thanks.
No power to window, corrosion inside door plug socket (not the usual)
Re: No power to window, corrosion inside door plug socket (not the usual)
I have a 2000 plate x reg megane. My electric window on. The drivers side front is not working it is clicking as i press the button. But wont open at all all power going to it but nothing at all will happen any ideas please
- Currently Drives:: megane privilege
Chloemae12. It's the window control module or temic unit. You can now buy new replacement ones off eBay for around £25 with a two year guarantee and you will need to find someone with the patience to strip down the door panel to replace it or spend a fortune at your local dealers,(not recommended!).
- Currently Drives:: 2005 megane sport tourer
cut one off at the breakers yard leaving enough wire so you can cut yours off and put the new one on
if at first you don't succeed get a bigger hammer
- Currently Drives:: 2007 megane 1.5 dci dynamique estate
I had the same problem, just one pin corroded. I was able to clean it up sufficiently well enough for it to work using wd40, fine needle files and fine emery tape. Its a bit fiddly but worth a go. Failing that do as tanto12 suggested get one from a breakers yard and solder it in.
Users browsing this forum: Google [Bot] and 63 guests
