rear discs
- Currently Drives:: Renault megane 1.6vvt dynamique
rear discs
hi can anybody tell me if my meganemk2 has the brake discs with the built in wheel bearings its a 56 plate
Re: rear discs
thanks Robbie
- Currently Drives:: megane privilege
Re: rear discs
Yes they do. You can buy discs with the bearings and abs ring fitted, but I'd recommend purchasing a bearing puller prior to doing the job to get the old ones off and make sure you tighten to the correct torque. I replaced them on my Clio a few years back. Not too difficult.
Re: rear discs
Personally I would replace with new bearings,the abs rings come off ok without breaking if your gentle.
Users browsing this forum: No registered users and 104 guests
