vacuum pumps
- Currently Drives:: Renault megane 1.6vvt dynamique
vacuum pumps
has anybody used a fluid extractor to change the oil I'm getting older and struggle to crawl under the car and change oil that way ,I can borrow a pela 6000 to try I don't think it would do no harm to try I know the amount of oil in the sump and would check it against the pela which holds 6 litres
Re: vacuum pumps
Most of the modern cars are serviced this way but unless your dipstick tube diameter is big enough to fit a suction tube down(which I doubt) or your dipstick tube goes to the base of the sump then I doubt it would work.
Re: vacuum pumps
thanks again I watched it being done on a megane like mine on youtube it seemed to work ok just go into youtube and you will find it
Users browsing this forum: No registered users and 65 guests
