Hello n00b CC owner here
I've got a 2007 CC, with cruise control and electric mirrors, both of these don't work;
When starting the car the cc light shows as orange with the other starting lights then goes off.
When pressing the cc/speed limiter button, nothing happens no lights show on the dash no messages.
The clutch switch looks OK, not checked the brake switch yet (I assume there are two as my brake lights work fine).
Where is the fuse for the cc located?
The mirrors also don't work, moving the switch in any direction doesn't cause any noise or movement from the mirrors.
Again where is the fuse located?
There was no manual supplied with the car, and I have checked the fuse box next to the glove box.
Questions Re: Cruise control, and Door Mirrors.
Pug 307HDI90 1.6 (family car)
Re: Questions Re: Cruise control, and Door Mirrors.
Craig, you do not say which model you have so the following info could be wrong.
Your problems are unlikely to be caused by fuses.
Fuse 5F (7.5amp) could control the CC and speed limiter but if blown, other services would be affected too. The signal from the "under steering wheel controls" as Renault calls them, goes to the ECU which controls this system
Fuse 7B (7.5amp) could control the door mirrors but again, other items would be affected.
Both these fuses are on the UCP (the "switching and protection unit") beneath a cover next to the battery and not easily accessible on a 2007 car. The door mirrors could be broken wires where the doors open. If you can access the UCP try removing all the plugs and putting them back in again. Water ingress can be a problem but by 2007 this well-known problem had largely been eradicated. Access to a wiring diagram would help if you are handy with electronics.
The best of luck...mate.
Mike
Mike
- Currently Drives:: 2007 Renault Megane CC Dynaique
Hi Mike thanks for the reply.
Just for info the Car is a 2007 Megane CC Dynamique. 1.6 VVT.
I have had the opportunity to do a bit of digging around with fuses in the dashboard, and there is a fuse which is in place for the heated mirrors, this is OK. Which based upon Renault design MIGHT have been the source.
I've tried another switch, which I thought might be the problem
I'll have a look under the bonnet tomorrow, but all other devices appear to be working as expected.
Thanks for you help
Thanks for you help
OK hopefully a simpler questions for the masses;
Do the window control switches for megane light up at night, passenger and drivers side?
Also does the mirror control switch also light up?
Neither of these are lit.
After a computer diagnosis at Renault, turns out a fuse had gone in the engine bay. Now my cruise control, door mirrors and the lighting to the window control panel all works
Thanks for letting us know Craig - I just wish more members would!
As a matter of interest, what did Monsewer Renault charge you for the privilege of plugging in his pooter?
A whole lot of man love....
£90 but had it been something a bit more serious that £90 would have been deducted from the bill.
craigf79 wrote: . . . When starting the car the cc light shows as orange with the other starting lights then goes off.
I've joined the forum to say thanks for the information in this thread, it helped me find and fix my problem.
I had the exact same problem as craigf79 on a Megane estate 1.5 dci 86, no cruse control or speed limiter symbols appearing on the dash when the button was pressed, the electric mirrors didn't work and the window control switches didn't light up.
Decided to take a look for a blown fuse in the engine fuse box (UPC as I believe it's called), eventually got it out after removing the battery, battery tray, and unplugging all of the connectors to it, what a stupid design putting fuses hidden away like this. There's videos on you tube if anyone needs to see how to do it.
Found a 7.5 Amp fuse blown, all the rest were ok, replaced the blown fuse and put the car back together, started the car to find the cruse control / speed limiter and the the electric mirrors working and the window control switches lighting up, so fixed
The only thing to note (apart from the stupid design of the engine fuse box ) was that the ESP warning light was displayed on the dash along with the message "ESP OFF" when the engine was started, pressing the ESP button had no effect, however as soon as the car was driven 10 meters or so the ESP light went out and all back to normal.
Apparently the ESP light coming on is common if the battery has been disconnected.
Thanks again for this thread, I hope my findings help someone else fix their problem.
Cheers.
- Currently Drives:: 2007 megane 1.6 dynamic vvt coupe
Hi chaps u am a new owner and have the same problem as the above, the fuse you are talking about are they the large ones next to the battery bay that I cant get to ?
Users browsing this forum: Bing [Bot] and 99 guests
