so, since aquiring this lovely piece of kit, ive noticed a odd smell ommiting from the passenger side of the vehicle (near side) its only really happening after the car has been warmed up or idle for at least 5-10 minutes. At first i thought it was electrical, but the more ive become acustom to it the more of a hot oil / engine smell its become! Im assuming its a oil leak of some kind as ive noticed it is slowly lossing levels not to mention the nice oil like dampness on the nearside of the block on the side! Checked both water and oil resevoirs and caps... no mayo, but heard of numerous faults including bust seals ect...
Can anyone shed some light as its the first thing on my list that i would like to solve / sort! ... no to mention it stinks lol i have an asumption that the leak is minor but due to it being on the block gives of the strong wiff when hot!
Any imput is welcome! But cant see any obvious head gasket related issues! No power loss.. no service light etc...
Awful smell when Engine is warmed up
- Currently Drives:: Renault Megane 2 HB 2003 1.6 Gasoline
Re: Awful smell when Engine is warmed up
Do you turn the heater on when you start the car? It could be about the air filters.
- Colsta
- Currently Drives:: Renault Megane Convertible 1.6 Dynamique
i thought yhe same but the smell is only when warm and can smell it outside as well as in.. but a valid point about filters i will check it! Its just odd as its a cross between a very hot engine smell and hot water / oil!! But no mixing or fluid loss on both! But is residue on block on nearside
emrekurubas wrote:Do you turn the heater on when you start the car? It could be about the air filters.
- almcgrail
- Currently Drives:: Megane II tourer 130
I know you said it's likely not to be electrical but it's worth checking electric window motor. Our meg would stink about 10 mins into driving and motor was burning out due to water ingress; said window is on it's third motor.
At least if you check it you can discount it.
Users browsing this forum: No registered users and 69 guests
