Hello again...
I just successfully replaced the headlight. Wow, that was more difficult than it should have been. I am still having an issue where my taillights flash disco style when I apply the brake with the turn signals on. I did replace a burnt out light bulb in the rear as well.
Any help you can offer would be greatly appreciated!
Thanks,
Kevin
Disco Taillights
Re: Disco Taillights
It will be down to a bad earth on the multi plug
You will need to replace the bulb holders or do what I have done many times in the past put an earth wire
From the earth on the bulb holder tithe body or patch it
In to the loom before the plug and you will be fine
I tried to remove the wire connector to check the earth wire (ground in American English?) and didn't want to break it. Is there a trick to releasing the housing?
Users browsing this forum: Bing [Bot] and 74 guests
