Passenger door slightly open (still locks)
Palmer291
Currently Drives:: Renault Megane 2010 1.6 Dynamique
Postby Palmer291 » Wed Mar 23, 2016 2:42 pm
Hi everyone,
I noticed a few days ago that my passenger door looked like it hasn't been closed properly. I checked it and shut it again but it didn't sit flush with the seal. The door still locks, but when driving I can hear wind noise and outside noises louder than usual which obviously means it hasn't shut properly.
Anyone know what this might be? I can't post pictures just yet as I'm currently at work, but I can supply some if needed later on.
The seal looks intact and the rubber around the door seems fine too.
Re: Passenger door slightly open (still locks)
Postby Stranger » Wed Mar 23, 2016 5:11 pm
You might need to adjust the staple (the loop on the B pillar) to pull the door tight.
steve-t
Postby steve-t » Thu Mar 24, 2016 10:08 am
I agree the loop has moved.
loosen off the torx bolts a touch and tap with hammer gently
Close door re adjust or tighten up.
Steve
Palmer291
Postby Palmer291 » Fri Mar 25, 2016 3:37 pm
Stranger wrote:You might need to adjust the staple (the loop on the B pillar) to pull the door tight.
steve-t wrote:I agree the loop has moved.
Steve
You're both geniuses! I never even thought of checking that.
Thanks both, I've got it fixed now. Didn't need to tape it with a hammer as the bracket was pretty much hanging off. The torx screws were pretty much hanging off and extremely loose.
Thanks very much for your help, you've saved me!
Postby Stranger » Fri Mar 25, 2016 6:31 pm
Pleasure, glad you've got it sorted :-)
steve-t
Postby steve-t » Sat Mar 26, 2016 5:59 pm
Happy to help
Steve
