Postby Phil and Liz » Fri Jan 29, 2016 7:27 pm
does the normal bulb still work ?, if so is the measurement from locating pins to base where terminals are the same ? if you put the led bulb in the bulbholder can you get access to press the terminals in the bulbholder ? if so does the bulb light up ?
Phil and Liz Jackson
Lanark
