Well radio decided to go off on my way home from work last night, lo n behold this morning then a flat battery within the space of 12 hours...
Taken the fuse out after RAC got me going again but the lights are still on around the radio...
Question is if the radio is dead how difficult a job to be replaced ( hopefully this is the problem) and if it's not what's drained the battery any ideas of any other causes please guys n gals ...?..
Tnxs in advance
MissM
Radio then flat battery
- Rally Driver
Re: Radio then flat battery
if its the standard radio its straight forward to change, if your battery was flat it may need the radio code putting back in , if you don't have this the radio has to come out to get to the label stuck on the side
Tnxs, gotta wait n see now if I have a flat battery again in the morning as the lights surrounding the radio are staying on....
Is the headlight access hatch cover missing on the front left wheel arch liner?
Not sure, will check if it is open will this cause issues ??
Well apparently I have a software update issue and only Renault can do this in the meantime I just have to disconnect the battery if the lights stay on until it can be booked in ..
Users browsing this forum: Bing [Bot] and 57 guests
