Temperature Gauge not coming to the halfway
Posted: Tue Oct 27, 2015 8:42 am
Hello,
I have Megane Sedan 1.5 dci 86 hp. Lately, I gave it to a friend for annual maintenance to clean EGR valve, the throttle, changing the oil and coolant, filters and so on.
The car seems fine after the maintenance however, the temperature gauge was coming right into the middle before the changes and now, after the maintenance, after it gets warm, it is not coming sharp to the middle but a little to the left, it is a very small discrepancy but still stuck in my mind. Do you have any idea what it might be, thermostat works fine and as I did not have any problem before the maintenance, can be related one of the changes that I have mentioned?
Just to add that the fuel consumption is good - keeping the same level and around 6 lt/100 km in city traffic and around 5 lt on the highway as I push the gas a little more than normal
Therefore, also no problems with the consumption.
Thanks in advance for having a look at the topic!
