Hi guys,
Thanks for any advice in advance!
I have a Megane Sport 225, 54 plate. 90,000 miles on the clock but I have changed/upgraded nearly everything on the car apart from the chassis.
I have had a really long and annoying problem with my motor that my mechanic can't seem to fix... the car ever so slightly veers to the left. It always has done and so far I have not found a remedy. It's still very much drivable I just thought I would try my luck with you guru's! If I let go of the steering wheel it will ever so slightly turn to the left and pull itself over, on some stretches of motorway I can completely let go on a long bend and it will get me round it perfectly, but it's still annoying!
My second problem is a more recent one and a lot more of a worry for me; the car while accelerating shudders lightly, I can feel it in the car and also mainly through the gas pedal, this is only while acceleration is happening and while sat in 6th gear cruising along it's not heard of at all. It only mainly comes if I accelerate hard above 4k+ revs. Could it be coil packs/spark plugs? I in my limited knowledge thought it could be them as I guessed the engine is missfiring?
Thank you so much any replies will be muchly appreciated
Problems with my Megane :(
- Currently Drives:: Renault Megane Sport 225
Re: Problems with my Megane :(
Any signs of it been in an accident
No, no accident at all; thanks
Is the steering wheel straight when driving on a straight line? If not, then adjust the steering rods.
Check the suspension geometry by the optical method (a naked eye and on flat ground).
Users browsing this forum: No registered users and 65 guests
