air con with can clip
Posted: Mon Sep 14, 2015 8:05 pm
by tanto12
hello folks
I am trying to find out if you can see the air con pressure using the can clip tool I have done other tests such as check compressor ,low speed fan and high speed fan with the can clip they all seem to be working I just cannot seem to find the reading for the pressure in the air con system
it is the air con with just the a/c button no climate control
thanks :?
Re: air con with can clip
Posted: Fri Sep 18, 2015 10:47 pm
by rfman
Not sure if that's possible as there is no pressure transducer fitted, only a high/low pressure switch.
Posted: Mon Sep 28, 2015 2:42 pm
by tanto12
UPDATE
ok I found the pressure reading and it was 0 bar so I suspected pressure sensor as this is a common fault so I changed the sensor for a new one but it is still reading 0 bar so now I am a bit stumped and still no air con
Posted: Tue Sep 29, 2015 5:17 am
by MeganeMule
If the px is 0 that would suggest there is no refrigerant in the system and that you have a leak somewhere. Take it to kwik-fit. If there is a leak there is no charge and then you will know there is a problem or you will have your A/C recharged (£49.99).
