Missing Reverae light!
Posted: Sun Sep 13, 2015 11:29 am
by hammondclan5
Hi Guys.
My Meg II 2003 has no working reverse light in the rear light units...
Bulb is there and has power but doesnt come on wjen I reverse...
Earth is intact and no error codes or anything.
Any ideas?
Thanks in advance
Re: Missing Reverae light!
Posted: Tue Sep 15, 2015 10:05 am
by Philthy
The bulb?
Sometimes they look intact, but are open circuit.
Posted: Tue Sep 22, 2015 3:19 pm
by jordyoggy
I had the same issue, what it could be is your referse switch has gone, a common thing.
You know this by: turning your window wipers on (not rain sensitive mode) and putting your car in referse. If your rear window wiper does NOT turn on, it's your switch. If it does its something else.
If the switch has gone fault, it located behind the left weal in the gear box (YouTube what it is and where it is) this can be pulled out with a spanner but gear box fluid will flush out too, so make sure you have some at hand to top it up. Remove the old switch, replace with a new one and plug it in. Hey presto it should work.
