Page 1 of 4
radio code
Posted: Sun Jul 19, 2015 9:25 pm
by johnny the fox
hi all, i had to replace my battery and i haven't got a radio code. can anyone tell me the easiest way of obtaining it and if poss free of charge? kind regards Johnny
Re: radio code
Posted: Mon Jul 20, 2015 5:55 am
by freelanderuk
If you have an android phone look on the play store for Renault radio code generator , down load and enter the code of the radio and it will give you the security code
Re: radio code
Posted: Mon Jul 20, 2015 7:07 am
by johnny the fox
i haven't got that type of phone but my daughters have i phones. would they do the same job? cheers johnny
Re: radio code
Posted: Mon Jul 20, 2015 7:40 am
by freelanderuk
i think there is one for apple also
Re: radio code
Posted: Sat Jul 25, 2015 12:32 pm
by funkyunderpants
If you don't manage to get hold of the app just post the barcode from your radio here and myself or somebody else will provide you with the correct code.
Re: radio code
Posted: Sat Jul 25, 2015 8:50 pm
by johnny the fox
hi ya, ile try and locate it. sounds like ive got to take it out? cheers johnny
Re: radio code
Posted: Sun Aug 02, 2015 7:33 pm
by johnny the fox
Hi ya, ive had a go at getting the radio out but to no avail. I assume i have to remove the radio via the 4 small holes at the front of the set. what exactly do i need to do to achieve this as i have tried various small screw drivers but with no luck? regards,Johnny
Re: radio code
Posted: Sun Aug 02, 2015 7:36 pm
by Stranger
johnny the fox wrote:Hi ya, ive had a go at getting the radio out but to no avail. I assume i have to remove the radio via the 4 small holes at the front of the set. what exactly do i need to do this as i have tried various small screw drivers but with no luck, regards,Johnny
Some stiff wire that you can bend in to a U shape (an old wire coat hanger is ideal for this).
You'll need to make 2 U shaped pieces, one for each side push them firmly into the holes and they release a flat spring which holds the radio in to the casing and then wiggle it out slowly so as you don't rip any connectors off.
Re: radio code
Posted: Wed Aug 12, 2015 4:32 pm
by adrianmartin
Hi there just had full valet and got electics wet after much wd40 on fuses for which I had to take BATTERY
out.have the no but no smartphone if someone can help me out would be grateful.
no is 8200300858TR104
Re: radio code
Posted: Wed Aug 12, 2015 4:44 pm
by freelanderuk
try 8852
Re: radio code
Posted: Fri Aug 21, 2015 8:03 am
by Philthy
I have the keycode generator if it's ok to link to it?
Re: radio code
Posted: Tue Sep 29, 2015 7:15 pm
by Irishrenault
Hi I'm looking for assistance in unblocking my radio. Details are
8200607918TT108
RNRDBE80852405
RENRDW330-10
FD0908250852405
Re: radio code
Posted: Wed Sep 30, 2015 3:27 am
by tanto12
hi Irishrenault
radio code 6839
Re: radio code
Posted: Wed Sep 30, 2015 12:42 pm
by Irishrenault
many thanks
Re: radio code
Posted: Sun Oct 04, 2015 4:23 pm
by Sparklylisa
Hi everyone, I can't seem to find the app on my iPhone??
Does anyone have a radio code for a Renault Megane serial number 8200483757T
Bought it off my cousin and he said he had to disconnect battery so has lost the code and never had a service book, any help would be greatly appreciated
Thanks in advance
