tie rods
Posted: Sun Jan 25, 2015 4:37 pm
by phil48
anyone know hows the best way to change the tie rods on my megane plz?
Re: tie rods
Posted: Mon Jan 26, 2015 4:14 pm
by tomalamix
what do you mean by the best way? there isnt too much to choose, take one out and put another...the access is very easy if you take the wheel out
Re: tie rods
Posted: Mon Jan 26, 2015 6:38 pm
by phil48
yeh ok thanks
Re: tie rods
Posted: Tue Jan 27, 2015 5:34 pm
by Wickydude
count the number of turns when you take it off the tie rod. That way you know how far to turn the new one on.
It's not exact (due to differences in manufacturing), you'll need an alignment check anyway, but at least you're somewhere close.
Re: tie rods
Posted: Tue Jan 27, 2015 6:17 pm
by AlexB
Video:
https://youtu.be/d3QI_S37JGUYes, find a way to preserve the settings. Keep in mind that the rod end may be slightly different if comes from a different batch.
Do tracking by the optical method - aim by a naked eye along the front wheel and at the rear wheel. Find the toe-out values in the manual and calculate the offset, they are specific to the engine.
Re: tie rods
Posted: Tue Jan 27, 2015 7:43 pm
by phil48
THANKS FOR THE REPLYS BUT ITS NOT THE TRACK RODS ENDS IM DOING ITS THE TIE RODS WHICH COME OUT OF THE RACK THANKS PHIL
Re: tie rods
Posted: Tue Jan 27, 2015 8:04 pm
by Wickydude
You don't need to shout mate
Apologies, I thought you meant the rod ends as that's usually what needs to be changed.
Don't know much about the rest of the rack, sorry.
Best download the manuals from the Problems section. MR364Megane3 should have some info on the steering rack.
Re: tie rods
Posted: Wed Jan 28, 2015 3:43 pm
by AlexB
Those are easy to replace. Turn the steering to the full lock, grab the joint housing of the rod with some tool and turn it gently. Careful, it is possible to damage the rack if the thread is overly tight. In my case, it wasn't tight at all. Put it back with a threadlock.
I used the replacement kits made by TRW, they come with everything including the rubber boots. I used this wrench to grab the joint (the toothed jaw). The space is limited, so I recommend this one.
Bahco 9072P Rev Ergo Adjustable Wrench 10"
Re: tie rods
Posted: Fri Jan 30, 2015 5:43 pm
by phil48
Wickydude wrote:You don't need to shout mate
sorry didnt relise caps lock was on wasnt shouting thanks for the reply
Re: tie rods
Posted: Fri Jan 30, 2015 5:45 pm
by phil48
AlexB wrote:Those are easy to replace. Turn the steering to the full lock, grab the joint housing of the rod with some tool and turn it gently. Careful, it is possible to damage the rack if the thread is overly tight. In my case, it wasn't tight at all. Put it back with a threadlock.
excellent thankyou doing them satuday thanks all for the replys cheers phil
