Megane 1.5 dci air bubbles in fuel line
Posted: Tue Jan 20, 2015 10:36 am
by cankwas
Hi all, I have a 05 1.5 dci which is having starting problems. I changed the glow plugs because they appeared to be dead. Starting issues still persist after new plugs. Cranking over in morning it starts then injector fault lights up. Looking in engine bay to the left clear pipes (fuel?) appear to have bubbles running through them. Could this be the cause? Any ideas on where to check for air ingress?
Thanks.
Re: Megane 1.5 dci air bubbles in fuel line
Posted: Tue Jan 20, 2015 7:48 pm
by tomalamix
ai bubbles on the return line is normal, bubbles on suction pipe isnt. please take a picture or describe better which pipe is with fully filled with fuel and which one is with bubbles, post back then.
Posted: Thu Apr 23, 2015 1:31 pm
by Colster
seems to be common on all diesel Meganes. Mines a 2006 1.9Dci 130. Same problem, and similar symptoms to yours. I'm about to change my holed pipe, so will update soon.
Posted: Fri Apr 24, 2015 10:10 am
by Colster
Changed my pipe this morning. The old pipe was chafed underneath, so couldn't be seen from above, but quite obvious when removed from the vehicle. Problem solved.
