Hi I have just put my front window down now it will not come back up, took door panel off when pressing switch up or down it moves about a inch or so, it seem to be jammed
all the cables seem to be intact .... how can I get the window up manually (need to, as have no garage for night time )
front window
Re: front window
hi found this
One of the rear windows on my Megane was stuck open.
I found here this clever trick which rectified the problem
(Worked for me/my circumstance - but may not work for all ...)
Sit in the car, doors closed and unlocked.
1: Unplug the fuse for the offending window
2: Re-insert fuse.
3: Press lock twice on your key card (this should activate deadlock and bring the window up 2-3 inches)
4: Unlock car as normal
5: Repeat steps 1-4 until window is closed.
6: Unplug offending window fuse to disable the motor.
(note 40A fuse is for the back windows. Front windows have a 25A fuse for each side located next to the 40A fuse.)
2: Re-insert fuse.
- Currently Drives:: Megane II 1.5 DCI OASIS 2006 55 PLATE.
Re: front window
Try the window reset:-
https://www.youtube.com/watch?v=mN3XSwooxOM
If not then it could be your regulator.
Regards
Regards
- Currently Drives:: 2009 Megane Privilege 4 door 1.5 dci
Re: front window
Hi again, would like to know if the window regulator mechanism are interchangeable will one from a five door fit my three door hatch ( front passenger ) Thanks again.... jaff64
Re: front window regulator
Re: front window
Hi no one can help
Re: front window
If you mean the cables then they are different for a 3 door than a 5 door as I've had to do this myself and ordered a 5 door instead of a 3 door!
Hope this helps!
Hope this helps!
Re: front window
jtaling wrote:Hi,
Hope this helps!
I concur
The cables are different.
There are some repair kits floating about on the bay of E !!!!!!
Re: front window
Thanks to all, for the replies .... that's a great help
Users browsing this forum: Google [Bot] and 89 guests
