Had this problem for last couple of weeks now just cant get rid of it.
Car starts fine from cold and drives around all fine but if i turn it off when cars at normal temperature it wont start again tried several times in a row it turns over but dont fire.
If i keep pumping the accerlating pedal i can sometimes get it to start.
This started happening after i put car back together after cleaning engine bay and removing aircon.
I have replaced the fuel filter and the crankshaft sensor and neither has solved the problem.
Hot starts
Re: Hot starts
What engine etc do you have?
Can you hear the fuel pump come on before you start it? Reason I ask is I had similar problem to you with my last car, fuel pump sometimes wouldn't activate when engine was warm. Could never find out why, in the end I had to splice another cable to the fuel pump to plug into lighter socket
Re: Hot starts
1.9dci what sort of noise am i listening for.
Users browsing this forum: Bing [Bot], Google [Bot] and 58 guests
