Hi
I have a Renault Megane 2 1.5dci 2004. I would like to buy a Fault Code Reader and resetter tool (off course much needed with one of these cars). Can anybody recommend one on the marker that works? I haver found one with the following protocols but do not know the protocol for the engine management on the 1.5dci.
Regards
James
OBDII Protocols: ISO15765-4 (CAN), ISO14230-4 (KWP2000), ISO9141-2, J1850 VPW, J1850 PWM
Fault Code Reader
- Currently Drives:: RENAULT MEGANE 2 HATCHBACK 1.5DCI 2004
Re: Fault Code Reader
JAMESBRANTON wrote:Hi
Regards
James
The Renault Clip is pretty much the Only thing that Will ler You access the ECU.
I have a Renault Megane II 1.6 16v (Benzen) and I was able to read and reset fault codes using a cheap AUTEL MS509 unit from eBay.. It's about 40$.. But be aware that Autel stopped producing these units and all the units on eBay are copies.. Anyway.. there is a cheaper product (which is also a copy) called MS309 (20$) will also do the job..
Users browsing this forum: Google [Bot] and 45 guests
