Hi, I have just fitted coilovers to a megane mrk 2 but now i have a knocking coming from the back left.. It seems to be a comman problem.. some say its the spring loosing contact when going over a pothole then making contact with the body, others say its the bottom ball joint. Others say its the spring tension.. The coilover is sitting at its highest setting... The drivers side is fine... I have checked everything. All is secure. I have repositioned the exhaust heat shield but still there..
ANY SUGGESTIONS ANYONE....
knocking from passenger side after coilovers fitted
Re: knocking from passenger side after coilovers fitted
what coilovers are they?
my jom coilovers knocked after a week on the rear cos the bush in the bottom of the damper was loose, bit of super glue n knockin the edges in and it was sorted!
Ta-Tec coilovers... There isnt any ball joints on the rear.. the shock is attached to the rear axel. the spring sits alone... im thinking the spring is loosing contact with the body when i go over rough ground then knocking back into place.. On the original springs there were rubbers which sat over a knuckle on the body.... On the coilovers there is no rubber and the hole on the top of the coilover is loose over the knuckle... I am going to remove the adjustment part of the coilover and refit the original rubber mount.. Weird thing is... its only the passenger side...
Super glue oh no no no !!!!
sent the lot back.... now waiting on apex springs and bilstein b4 shocks... fingers crossed this time
Users browsing this forum: Google [Bot] and 120 guests
