Megane CC 1.6 2008 - "Engine Whine"
katonna
Currently Drives:: Megane CC 1.6
Postby katonna » Thu May 08, 2014 2:41 pm
I have a Megane CC 1.6 2008 and the engine seems to whine all the time. Obviously its most noticeable when pulling away or even sitting still if you rev the engine.
Any idea if these engines just do that or is there an underlying problem?
Meganeccdarren
Currently Drives:: Megane cc
Re: Megane CC 1.6 2008 - "Engine Whine"
Postby Meganeccdarren » Thu May 08, 2014 10:34 pm
Are you sure it's the engine? Could it be the clutch thrust bearing? :(
VroomVroomClonk
Currently Drives:: Megane 1.9 DCi CC 2004
Postby VroomVroomClonk » Sat May 10, 2014 12:38 pm
Try it with headlamps, fog lamps, rear demist and air conditioning all turned on at once, and then again with them all turned off. Does that make any difference? My guess is that it could be a bearing somewhere related to the engine drive belt. Mine certainly whines slightly when the air conditioning is on.
