Ok so mrs went out today and came back with a 2006 megane 1.5 diesel
Lovely car but found some issues already
hope fully someone can shed some light
1.. wipers are fine but no water from the jets
2. .high level brake light on all the time with lights.
lights off brake lights work as normal
also causing a issue with the cig lighter thingy
press brake it lights up lol
no power to external devices
3. mrs just popedto her mates 20 mile away , and a spanner light has came on .. electrical fault
stereo turned off ... then back on
wish id gone to view with her now
any help or advice would be great
dave
2006 diesel , few problems already
Re: 2006 diesel , few problems already
hi
is there water in the screen wash, jets blocked , pump not working. high brake light , earth problem , check the wires in the loom between body and boot lid are not broken or worn ( common problem)
somebody else may have an answer for the others
Had the same issue regarding the water pump - could hear the pump running but no screen wash...
The pumps wear out. replaced it and it was fine.
Pump is located on the washer bottle RH wheel bay. Remove the liner, and the water bottle is right there in front of you. The pump is on the front of the bottle and just pulls out. the same pump does front and rear washers.
2005 Scenic 1.9Dci 120 Exception
Willl check those today
thanks
now to check the other niggles
believe thee is also a fuse that covers the stereo / lighter etc etc ?
thanks
Users browsing this forum: No registered users and 63 guests
