Got ABS fault narrowed down to rear RHS wheel on my 2005 dci 1.5. Been advised to swap over rear hubs to confirm its the hub thats the problem if the fault changes to LHS.How hard is it to sway the rear hubs with each other?
Chris
How hard to swap rear hubs?
- Currently Drives:: 2006 MEGANE dci
Re: How hard to swap rear hubs?
Swap on sway
- ikhan
The ABS ring are built into the rear discs, so can you not simply swap them over?
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Lowered 45mm (Spax)
Thanks for the reply. So can I simply swap hub and disc or just disc to see if fault changes to other side?
I can see no reason you couldn't. The abs part on the disc is simply a magnetic ring, your problem maybe some dirt or something or even damage to the abs sensor, you will be able to see this when you have the disc off tho.
Thanks. I'll have a try today.
- ikhan
Cleanability wrote:Thanks for the reply. So can I simply swap hub and disc or just disc to see if fault changes to other side?
Just the disc...
Lowered 45mm (Spax)
Lowered 45mm (Spax)
Users browsing this forum: Google [Bot] and 84 guests
