Ok so I have been looking in to my ac it is fully gased and I have cleared fault code and worked great that day next day nothing checked codes nothing.its got gas am thinking it might be pressure switch as the compressor dose not kick in but when you turn the switch on inside the cooling fan cuts in as it should turn switch off fan stops so is the switch working as the ecu know its got pressuer to turn the fan on. I have tested the clutch that works just no power. I have also had fues out on body contorl unit thats ok so am thinking is it body contol unit fault. So my question to you is if ur pressure switch fails will ur cooling fan still kick in and would it leave a fault code.
Thanks for any help guys will let u know wat I find
megane air con fault just a quick question
Users browsing this forum: No registered users and 80 guests
