Heater Blower Motor
Anomolouswizard
Heater Blower Motor
Postby Anomolouswizard » Mon Feb 10, 2014 10:42 pm
My heater blower motor is only working on full speed (4) is this a common problem & how is it fixed?
Thanks.
2004 Megane Expression Vvt 1598cc 5dr Estate Auto
ET53ODE Mileage 43772 (at last service).
Marymegane
Currently Drives:: 2003 52plate 1.5 dci 80 megane 2 hatch dynamique with comfort pack
Re: Heater Blower Motor
Postby Marymegane » Tue Feb 11, 2014 2:32 pm
The fans seem to work through a resistor when this happened to mine I took it to my auto electrician he Re-did it for 35 quid a few years ago never had any bother since
livewire
Currently Drives:: Megane mk1 (99)
mk2 (04)
Citroen xsara (02)
Postby livewire » Tue Feb 11, 2014 7:16 pm
see this post.
should tell you all about it.
viewtopic.php?f=2&t=19540&p=117710#p117710
Anomolouswizard
Postby Anomolouswizard » Wed Feb 12, 2014 2:50 pm
Thanks for your advice. :D
Anomolouswizard
Postby Anomolouswizard » Fri Feb 14, 2014 12:23 am
Changing the Resistor assembly has fixed the problem. There is a good video on youtube.
https://www.youtube.com/watch?v=XI2MJl8W0yE
:D
livewire
mk2 (04)
Citroen xsara (02)
Postby livewire » Fri Feb 14, 2014 7:40 pm
good you fixed it.
but i believe that the correct thing to do what i have shown. (if it is the connector burning issue and not the resistor itself)
as the issue is with the design / material of the connector.
you have replaced it but it will / could burn out over time.
and my fix costs nothing (well just the connector block if you not got any ) and is a safer permanent repair.
