Heated seats
stevieb6
Currently Drives:: 2003 megane fidji convertible
Heated seats
Postby stevieb6 » Sat Nov 30, 2013 7:55 pm
Could you tell me if I have heated seats please, In the fuse box under the stearing wheel there is a picture of a headted seat, on the dash next to the dash dimmer knob there is a switch with a heated seat picture and under the front seats there are wires. When I flick the switch nothing happens but I dont think there is a fuse in the hole but I cant work out which hole it is, Im a bit thick when it comes to this sort of thing. Any help would be great as its driving me mad. I have a 2003 megane fidji convertible 1.6. thanks Steve
Re: Heated seats
Postby Paddy » Sun Dec 01, 2013 12:39 am
Evening lad.
A few pictures would help the diagnoses.
stevieb6
Re: Heated seats
Postby stevieb6 » Sun Dec 01, 2013 11:43 am
Ok I will get on that and post them this pm thanks
stevieb6
Re: Heated seats
Postby stevieb6 » Sun Dec 01, 2013 9:26 pm
Hope this works Paddy.Image[img]htt[URL=https://s783.photobucket.com/user/nottm335/media/010.jpg.html][IMG]https://i783.photobucket.com/albums/yy114/nottm335/010.jpg[/img]p://i783.photobucket.com/albums/yy114/nottm335/015.jpg[/IMG][/URL]ImageImageImageImageImageImage
I hope this has worked and you can see the pics ok
stevieb6
Re: Heated seats
Postby stevieb6 » Sun Dec 01, 2013 9:43 pm
Sorry I missed this one. If you need to me to explain the pics just let me know mate
Re: Heated seats
Postby Paddy » Sun Dec 01, 2013 10:08 pm
Sorry to burst your bubble lad. But you don't have heated seats.
The image on the fuse diagram is standard for every car, no matter what extras or lack of them the car has.
The wires you see are for the side air bag and the seat belt pretensioner. Both built into the seat.
If you had heated seat there would be two individual switches for both seats.
Put on a coat on the cold mornings!! :cool:
stevieb6
Re: Heated seats
Postby stevieb6 » Sun Dec 01, 2013 10:59 pm
lol. Thanks for that mate at least now I can stop trying to get them to work (would have been trying for a long time as they are not there)
Re: Heated seats
Postby Paddy » Sun Dec 01, 2013 11:02 pm
No bother lad,
Any other questions, you know where to find me!
stevieb6
Re: Heated seats
Postby stevieb6 » Mon Dec 02, 2013 9:05 am
I do have another problem Paddy which hopfully you can advise me on. When I turn my heater on it will blow for a few minutes but then nothing other than a clicking sound, any ideas what it could be and how to fix it?. Although having no heat isnt a problem in its self its the fact that I cant de mist the windscreen and it is a little dangerous driving like that I am having to drive with all windows open to try and clear the windows enough to see out off. I know I should buy a manual but I can only find one for a scenic and thats not what I have have. Thanks. Steve
Re: Heated seats
Postby Paddy » Tue Dec 03, 2013 11:53 pm
What has happened is one of the 'teeth' on the cog that changes the air from external intake to recalculating has broken off and has locked the 'falp' in an intermediate position that blows no air into the car.
This is a common problem and expensive to fix properly.
However the solution is...
If you open your bonnet and look at the grill just under the windscreen, to the RHS is where the heater matrix is located.
You need to pop the grill off and you will be presented with a connector. Disconnect this and wrap with insulating tape.
Then take a coat hang and push the flaps to the open position. ( You will know what this this is when cold air from outside is being fed through your air grill in the car).
The above locks the assembly toonly taking in air from the outside. Allowing both warm air and your windows to demist. ( One turning the heating nob)
Not a perfect solution as you will no longer be able to have the function of recirculating air. But will allow both warm / cold air and the windows to demist.
Much better than the £400 it will cost for a new unit and fitting.
If you are still unsure what to do.. I will look out some photos as a guide.
stevieb6
Re: Heated seats
Postby stevieb6 » Wed Dec 04, 2013 6:27 pm
You are such a great help thank you very much. Due to my shifts it will not get looked at till next Tuesday now but I will let you know how I get on with it. Cheers bud
Users browsing this forum: No registered users and 46 guests
