keycard
keycard
Has anyone had any luck fixing the replace battery fault on the keycards. Checked the board and everything looks fine and the card still works but this is a pain. Surely its a simple fix and you know where to look
- 12noon
- Currently Drives:: Renault Megane 1.6 Authentique 2005
Re: keycard
My key card is working, but the dash says replace battery. I'm guessing that the signal strength is weak coming from the key card because the wiring is loose in the card itself. I'm just hoping the card doesn't fail. I've search the net and read about people opening the card and using solder, but don't fancy doing that myself.
Has anyone got any keycard advice without having to go to the expense of buying a new one ?
2005 Renault Megane Dynamique 1.6 16V (Manual / Petrol)
Users browsing this forum: Bing [Bot] and 52 guests
