Hi all,
This just happened. My aircon doesn't work, all the dashboard lights are working (check photo)except the display panel one where you see the temperature and fan indication. It wont work at all, with the cold mornings I need air to clear my windows. Has anybody got a solution?
Its a 2006 Megane station wagon
Aircon problem
Re: Aircon problem
Just checked, the cigarette lighter doesn't work, the windshield spray neither and the radio does not switch off when opening the door
- Rally Driver
Re: Aircon problem
i would check the fuse box for the corresponding fuses and check they have not blown
Re: Aircon problem
Took it to a Renault dealership today, he didn't have much time as he was busy but he doesn't know what the problem is. He's sure its not a fuse though. He said it might be water damage or a break in the wiring. Made an appointment for next Wednesday for him to look at it closer , so unless I find an answer on here I'm broke until Christmas
- Rally Driver
Re: Aircon problem
I am sure that I read some ware that the CIG lighter and radio and possibly other things are on the same fuse,
Its easy enough to check your self before you go to the stealers
Re: Aircon problem
The dealer checked out the fuses, nothing wrong there
- Currently Drives:: Renault Megane 1.9 dci 2004 manual 5 door hatch
Re: Aircon problem
Symptoms were the same on mine but the aircon was totally dead, none of the lights came on, radio and cigarette lighter also the same as yours. Replaced the 15 amp fuse in the glove box compartment fusebox, second from the top, middle row. Replaced two days ago and still working fine.
- morganjake1544
Re: Aircon problem
http://ray-lee.co.uk/megane/dialogys/MR364MEGANE8.pdf
See page 46, fuse 'G'.
(G) 15 A Radio - offset display - headlight washer pump relay - first row cigarette
lighter - heated seats - screen washer pump - diesel fuel heater relay -
air conditioning control panel - AC control unit - auto-dimming rear-view
mirror - Protection and Switching Unit
Users browsing this forum: No registered users and 47 guests
