ignition probs
natty36
Currently Drives:: renault megane 54 reg diesel 1.5 dci
ignition probs
Postby natty36 » Sun Sep 16, 2012 9:18 am
hi all i have a renault megane 54 reg diesel 1.5 dci, had few probs with it starting so had new b( has last battery was completly dead) put on now shes starts, but it seems whne i take the key card out of the slot the dash boared etc isnt shutting down, the steering isnt locking either, the drivers window doesnt work how it should do and the wipers cum on at there free will, the system seems to clsoe down once car is locked but thinking sumthing is draing the battery has any body got any ideas please
tomalamix
Re: ignition probs
Postby tomalamix » Thu Oct 11, 2012 1:29 pm
search for UCH water ingress in the forum, the symptoms point in that direction...
good luck
peter h
Currently Drives:: Renault Megane 1.6 VVT Dynamique Auto
Re: ignition probs
Postby peter h » Fri Oct 12, 2012 9:33 am
natty36 wrote:hi all i have a renault megane 54 reg diesel 1.5 dci, had few probs with it starting so had new b( has last battery was completly dead) put on now shes starts, but it seems whne i take the key card out of the slot the dash boared etc isnt shutting down, the steering isnt locking either, the drivers window doesnt work how it should do and the wipers cum on at there free will, the system seems to clsoe down once car is locked but thinking sumthing is draing the battery has any body got any ideas please
minw does similar but none of the random moving stuff.
imine is a 2008 meg 2 and i press stop and remove the key. the dash lights are still on and lights etc until i press the lock key when everything turns off. i think its ment to work that way. but would look at your drivers door wiring loom. as i have had mine replaced recently.,
