Newbie With Problems
denz.m
Postby denz.m » Fri Aug 31, 2012 8:55 pm
Hi All, i have just baught my second megane its an 02 plate 1.4, baught it as a non runner it turns over but just doesnt fire ive checked that it has spark all ok. have bin told it could be immobiliser/key?? typical renault electrics i supose lol Any Ideas? Thanks
Re: Newbie With Problems
Postby davelowe » Fri Aug 31, 2012 10:11 pm
Plug it into CLIP and see what you can and can't access.
denz.m
Postby denz.m » Wed Sep 05, 2012 8:35 pm
Ive put the car on a diagnostics and it came up as the throttle body sensor, so changed that and still didnt start but check injection came up on the dash? Any ideas?
Postby davelowe » Wed Sep 05, 2012 10:15 pm
Well, check injection should trigger an OBD code. Keep trying...
The manuals in this forum have factory diagnostic procedures in them. Have a read.
denz.m
Postby denz.m » Thu Sep 06, 2012 4:45 pm
Thanks will do that soon as i get 5!
denz.m
Postby denz.m » Fri Sep 07, 2012 8:25 pm
Just a quick 1, i noticed that the wires off the clutch switch were off not the top 1 but the 1 more to the back of the pedal would this stop it starting? Thanks
Postby davelowe » Fri Sep 07, 2012 10:10 pm
Yes - if you only depress the clutch. Try both brake and clutch. This is a well documented problem. (Hint: search!)
Users browsing this forum: Google Adsense [Bot] and 22 guests
