cutting out.
jayc243
Currently Drives:: megane 1.6vvt
cutting out.
Postby jayc243 » Sun Aug 26, 2012 7:03 am
hi all,im stressed :cry got a 2002 1.6-16v starts fine runs for bout 20 seconds and cuts out keeps doing this until warmed up then it will tickover but runs rough.ave put new battery on, changed tdc sensor and coolant temp sensor can anyone help :(
denzilpc
Currently Drives:: megane convertible
Re: cutting out.
Postby denzilpc » Sun Aug 26, 2012 8:16 am
hi mate does the engine rattle as well ? if so sounds like the dephaser pully had the same problem with mine 12
jayc243
Re: cutting out.
Postby jayc243 » Sun Aug 26, 2012 11:50 am
hi mate, no it doesnt appear to rattle,pretty quiet.No ecu light either.
morganjake1544
Re: cutting out.
Postby morganjake1544 » Sun Aug 26, 2012 3:21 pm
Maybe coil/s. That could account for rough running and cutting out.
MicKPM
Currently Drives:: Megane II dCi, LAguna II GT Turbo (Petrol), Renault 19 16v (Ex-Tim Harvey RDR shell)
Re: cutting out.
Postby MicKPM » Sun Aug 26, 2012 4:39 pm
Throttle body... remove it, clean it, refit it and I bet your problem is solved.
Mick
jayc243
Re: cutting out.
Postby jayc243 » Mon Aug 27, 2012 6:18 am
cleaned throttle body allthough it wasnt really dirty.stil the same
Re: cutting out.
Postby AlexB » Mon Aug 27, 2012 9:28 pm
Use OBD. Read the fault codes first, then record and plot the live parameters when replicating the fault. Post the plots here for discussion.
tomalamix
Re: cutting out.
Postby tomalamix » Tue Aug 28, 2012 9:46 am
as far as i understand there will be no fault on the OBD scanner, the engine simply goes out...
the problem stops when its warm, something related with the car temperature can cause the fault.
did you serviced the car recently?
Re: cutting out.
Postby AlexB » Tue Aug 28, 2012 10:11 am
Keep guessing then...
If it is something temperature-related, then it will show on the live diagrams. It doesn't need the temperature itself, but a relationship between various parameters.
I strongly advise to use OBD, and not just to scan for fault codes!
tomalamix
Re: cutting out.
Postby tomalamix » Wed Aug 29, 2012 10:20 am
yes, in that terms i agree, like Alex told life data can give good info on whats is going on. do you have a obd scanner?
MicKPM
Re: cutting out.
Postby MicKPM » Wed Aug 29, 2012 2:46 pm
Live Data from a generic EODB scanner will be very limited and I doubt you'll see anything regarding the IAC with Mode7 data... deffo needs a proper session though.
Mick
Re: cutting out.
Postby AlexB » Wed Aug 29, 2012 3:57 pm
An Idle Air Control fault is actually diagnosed with OBD. It will show as low calculated load plus revs hunting while everything else being consistent...
