side lights
side lights
can some 1 please help me my side lights, number plait lights and reverse lights have stopped working i have changed the fuse and relay but still nothing. i have front lights and front and back fog lights im not sure what else to look at. i took it to a local garage and he said it will cost a lot to fix but he can by pass it but it wouldn't pass its mot. my boyfriend said it might be the stork is there a way to check it?
- morganjake1544
Re: side lights
Front or rear sidelights? Or both?
Re: side lights
both, my reverse light went months ago. my lights wouldn't turn off 1 night they kept flickering and the next day i just had my front lights but no side lights or back lights or number plait lights. my break lights work and so do my fog lights.
Re: side lights
Disconnect the battery negative lead, remove the rear trim to expose the wiring from the rear clusters (take them off too). Then trace the wiring back to any bolt on the chassis. Check that all the connections are not corroded. Put it all back together (this should not take more than 30 minutes), then reconnect the battery and see if it works.
You have checked the bulbs I assume?
Also, what car do you have?
Re: side lights
its an 03 megane yes we have checked all the bulbs, thanks for ur help, il give that a go. iv just booked it in to renault but id rather sort it myself then pay out loads. lol.
