My 2005 1.4 Renault Megane starts and then cuts of unless you hold down the accelerator, The mechanic says its the throttle body but says he can replace it but hasn't got the equipment to programme it. ( video below)
Is it true that the throttle body requires programming?
Is it worth trying to clean the throttle body?
Renault Megane 2005 1.4 STARTS THEN CUTS OF
- Currently Drives:: Renault Megane
Re: Renault Megane 2005 1.4 STARTS THEN CUTS OF
yes, is completely worthy to clean the throttle body first...
cheers
cheers
tomalamix wrote:yes, is completely worthy to clean the throttle body first...
cheers
Thanks I'l give it ago , do you know if a new throttle body needs programming? - I have heard it does not
Cleaning the throttle body is definitely the way to proceed. It is the number one problem on the 1.4 engines.
I doubt any sensor is to blame as the car does start, it immediately stalls - the starter would crank for ages if not.
Your first post, by the way, is the best possible way to describe the problem!
Users browsing this forum: Google [Bot] and 69 guests
