do dci's have breather clogging problems ?
Posted: Sat Jun 23, 2012 6:40 pm
hi again,
i had the utter misfortune today of removing / cleaning and replacing a corsa c 1.3 cdti starter motor.it was a pig of a job to get to a bolt and i had to remove the main breather(i thing thats what it was) up to the intake.anyhows when i took it off it was blocked up with dried out hardened oil deposits..and i mean BLOCKED.the breather pipe was about 1 3/4 inch diameter and it was solid apart from a small hole and the end of the intake was as bad...so i was wondering if meganes have a problem like this that need cleaning out once in a while ?
i read somewhere that driving miss daisy style does these engines no good what so ever and once in a while you need to drive it like you stole it ...any thoughts anyone..would it be worth stripping it down or not ?
cheers..dave.
cheers..dave.
