Engine light on with fault code
sbtjap
Postby sbtjap » Fri May 04, 2012 10:11 am
My Service Engine Soon light just came on. Took out my Renault CAN Clip Diagnostic Interfaceand the following codes came up: P1086, P1084, P0172, P0175. What should I be looking for when trying to fix this problem?
FOOTBALLGETTO
Currently Drives:: Megane II 1.5 DCI OASIS 2006 55 PLATE.
Re: Engine light on with fault code
Postby FOOTBALLGETTO » Fri May 04, 2012 10:43 am
Running too rich, fuel/air mixture. Thinking could MAF related. Is it worth cleaned the MAF with the dedicated MAF Cleaner?
Also make sure that the housing around air filter/MAF has no splits.
What megane are you running Petrol or Diesel
Regards
Tony
Postby AlexB » Fri May 04, 2012 5:42 pm
Is there a typo in the first two codes?
The last two are about too little oxygen detected by the O2 sensors. Look at the graphs of live parameters for the further analysis.
