panoramic sunroof sticks when trying to open
- Currently Drives:: 1.6 Renault Megane 57 plate 43,000 one owner full service history
Hi has anyone had the same problem ?> ive got a 1.6 Renault Megane 57 plate, The sun roof seems to stick when trying to open it after a few trys it does open sometimes i need to push up by hand Appreciate any advice Thanks Neil
Re: panoramic sunroof sticks when trying to open
No idea, I don't have one. Try reading the manual in the sticky thread first.
Don't you think it needs sun to operate?..
- Currently Drives:: megane II 1.9 dci dynamique
my sunroof had the same problem. i fixed it by opening the roof to half way, then removing the two T25 torx screws on either side of the window when looking at the sides from inside the car, then carefully undoing the T25 screws on the rear runners. with some assistance lift the glass over the car and rest it somewhere safe. then get some silicone GREASE not spray. then put some in the runners and move the rear runners back and forth a bit to spread it about.
you could put a light smear of silione grease on the sealing rubber to soften it up again. dont worry the silicone grease wont have an advere effect on the rubber. that fixed mine
hope it helps
hope it helps
It's more likely to be worn rubber feet/bushes on the lifting bracket. Do you get a rattle when driving ? Open the sunroof to first setting , look on side of sunroof where the torx bolt is and where the bracket goes into the runner you should see two rubber feet/bushes.
There is a replacement via Renault but they want £80 !!
Quick look on eBay.co.uk and they are around £20, but no idea how good quality they are.
I got a replacement set for around £8 on ebay. I have replied to a previous thread with links to the plastic bush things and also a link on how to change them
seems to be a common problem
I don't have clue for my one before just clicking. Today in the morning I put on full open and is smooth open... Then smooth closed now again just click... Help,please
My sunroof dose this to can anyone send me link to fix it
s88urd wrote:I got a replacement set for around £8 on ebay. I have replied to a previous thread with links to the plastic bush things and also a link on how to change them
Can you send me link please
Instructions for the job -
http://www.meganeclub.nl/fora/index.php?topic=17086.0 (Translate the page to English)
The plastic clips -
https://www.ebay.co.uk/itm/Renault-Scen ... l%3AMegane
or
https://www.ebay.co.uk/itm/4x-CLIPS-FOR ... SwiHpaOPOz
Plastic clips + metal arms -
https://www.ebay.co.uk/itm/RENAULT-MEGA ... SwTFNZdwrq
Cheers.
The plastic clips -
or
Cheers.
