diesel 1.5 on 1st startup ticks loud, ok when warm?
dano2387
Currently Drives:: megane 1.5dci
Postby dano2387 » Tue Apr 17, 2012 7:28 pm
hi there
i did search forum prior to question but had no joy. the diesel megane is my 1st diesel i have owned, and i have noticed when i start up first thing when cold, it ticks very loud. but when warm, its fine.
the oil levels fine as is water etc and its driving perfect and no signs on dash, and still getting my 50-70 mpg.
so am i just worrying over nothing?
please please advise
Re: diesel 1.5 on 1st startup ticks loud, ok when warm?
Postby davelowe » Tue Apr 17, 2012 9:46 pm
Unless someone has a better idea, I'd say you were worrying over nothing. Worst case is that the valve adjustment is loose, but without consulting the manuals (you should), I can't foresee anything adverse. If applicable, this tends to affect only engines with very high mileages.
dano2387
Postby dano2387 » Wed Apr 18, 2012 6:38 am
thanks for your advice Dave. i have tried searches on google with nothi coming up so probably nothing.
Postby AlexB » Wed Apr 18, 2012 9:39 am
At idle revs this may be caused by low quality oil.
darkmast3r
Postby darkmast3r » Wed Apr 18, 2012 9:56 am
My 53 plate 1.5dci (50000 miles) certainly is more noisy when first ticking over, especially on a very cold morning. I don't think it's anything to worry about. I've had mine for just over 2 years and it's always been like it and I use mobil oil. My wife has a 58 plate peugeot 207 1.4 dci (20000 miles) and thats very similar when cold.
Postby AlexB » Wed Apr 18, 2012 10:47 am
Just guessing... When the engine is cold, it injects the charge in one go. A burst of several injections is used on a warm engine, which sounds smoother. Check the temperature readings on OBD.
tomalamix
Postby tomalamix » Wed Apr 18, 2012 11:43 am
im with Alex, low quality oil produces that
And im with dave, valves clearance may be out of limits which can get better while the temperature rises and the metal expands...
give some news..
dano2387
Postby dano2387 » Wed Apr 18, 2012 4:15 pm
thanks for all comments i must say that i have paid close attention to it and it does still tick when warm just no where near as loud.
i think i need to find out what oil is advised fr diesels with high miles. as thats ehat i think it is.
my dci is a 53 plate with 118k on clock , service was done 4000'miles ago. im wondering if cheap oil been used and now iv covered a couple thousand miles, its got thin.
any recommendations on what thickness of oil to purchase?
thanks
tomalamix
Postby tomalamix » Thu Apr 19, 2012 10:13 am
Use some oil flush product also, it will help to clean the engine inside. Bardhall have a product for that purpose but i know there are several others...
For the oil, check this: viewtopic.php?f=2&t=19714
cheers
Postby davelowe » Thu Apr 19, 2012 10:03 pm
Oh hell! Be warned that these products can make a bad problem terminal for the engine. This is an age old debate, but I would not put kerosene into my engine to thin it. Big bits of crap tend to break off and block small engine passages, ruining the engine.
If it runs okay, I would leave well alone. Do several oil changes with Mobil 0W40 with filters too - the detergents in this oil will clean your engine gradually. Say 500 miles or 1000 miles between changes. More expensive in the short term, but not terminal.
Postby joeishmather » Thu Apr 19, 2012 10:16 pm
I used to run thru cheap tesco oils to give it abit of a 'rinse out', like it's been said above the 'cleaners' can have the opposite affect to what your after!
biggydoug
Postby biggydoug » Wed Apr 25, 2012 6:49 pm
just seen your post my guess would be leaking injector seal
sounds bad but its just a small cooper washer you can get them from renault for about 1.50 i had same problem on my car best way the check is look at your injetors and there will be carbon around hit or just smell neart the engine when running
Postby davelowe » Wed Apr 25, 2012 9:52 pm
biggydoug wrote:just seen your post my guess would be leaking injector seal
Interesting... I would like to know how this unfolds.
