Help card reader not picking up card
mikey2704
Postby mikey2704 » Fri Feb 24, 2012 6:51 pm
Good evening
I was wondering if anyone could help me please?
My card will unlock the doors but it wont start the car. When i use to open the car it would say insert card but now im not getting any lights on the dashboard.
Thanks in advance
Mike
sixties_kid
Currently Drives:: Megane II Sports
Re: Help card reader not picking up card
Postby sixties_kid » Mon Mar 26, 2012 9:34 pm
Hi Mike
not sure if you have solved this now but if it is the same issue I had the induction coil in the card has broken solder joints.
in the interim i removed the console and had the card reader 'dangling out' so I could squeeze the card when it was in the reader, squeeze the right side where the emergency key goes and you may be lucky.
there is a repair for this on the forum but it is tricky and I managed to b*gger the coil with the scalpel opening up the key card - had to get a spare off ebay to salvage the coil and now all works
you don't mention a 2nd/spare card so i'm guessing you have the one only?
however, if both of your keys don't work then it may not be the key/coil issue
good luck
L
