I hope I have posted this in the right section, if not please feel free to move it admin
I owe it to all the users of this forum to post my solution as I have gained invaluable info since registering on the site. You may also notice this is only my first post.
So a little background;
I like the rest of you have had many problems and have replaced many parts;
2x O2 sensors
TDC sensor
Coolant temp sensor
4x Coils
top and dogbone engine mount
drive shafts
window regs
I have had a rattly depaser pulley on start up from cold and sometimes from starting from warm, the pulley would rattle when the engine starts and then stall. I would have to rev the engine slightly before the engine would then idle properly.
Nice, cheap and simple solution that worked for me (and I hope it works for you)
I did an oil change and added 2 cans of oil flush to the old oil and ran the car as instructed on the can.
I then did a mini service and hey presto!
Since then I have not heard a single peep from the pulley and the car has started first time, every time!
I can't believe this could be a coincidence but I'm sure others will try to tell me different, it has worked for me, that's all I'm saying and it could work for you!
Please post on here if my solution works!
I hope this helps guys, good luck and happy motoring!
Paul
Rattling dephaser pulley solution megane 2 1.6 16v vvti!!
Re: Rattling dephaser pulley solution megane 2 1.6 16v vvti!
Quick update..
I did this 1 mont ago and still not a peep out of the pulley so far. This has been a 100% solution for me!
- Currently Drives:: 1.6 16v megane2 sedan
When I bought my megane 05 (1.6vvt) It had a slight rattle noise near the dephaser . I suspected the dealer never had the car serviced as he promised , so I did my home work and did a full service . After the service (oil and filter change) the motor has been purring like a kitten ! Im sure these dephasers have very fine tolerences and need a specific quality oil and clean filter to work properly !
- dean-weston
- Currently Drives:: 54 Megane 2 - 1.6VVT
pr3man wrote:Quick update..
Hi, please have a look at my post viewtopic.php?f=2&t=19167 regarding rattling dephaser, I have just done an oil change this evening after running a can of flush through it, filled up with 5\30 oil - im now just waiting till i start it up in the morning to see if its cured it
- dean-weston
dean-weston wrote:pr3man wrote:Quick update..
Hi, please have a look at my post viewtopic.php?f=2&t=19167 regarding rattling dephaser, I have just done an oil change this evening after running a can of flush through it, filled up with 5\30 oil - im now just waiting till I start it up in the morning to see if its cured it
Well, 1st start up @ 07:15 (although it was not particularly cold morning) - no noise from dephaser, car seems to be driving better... more torque, better acceleration and response, sounds a bit better on tick-over too.
The old oil was BLACK , I don’t just mean dirty, it was horrible. ALSO, whilst changing the oil I removed the dephaser solenoid and gave this a good clean with WD40 and then dipped it in clean oil and replaced.
So if in 10 days this is still working, im planning another flush and oil change to ensure any crap and gunk is out of the system.
What oil is recommended, im currently a running 5w30 fully synth from UniPart ??
Thanks all.
D
Thanks for information. Did your car judder in 1st gear also until it warmed up.
Users browsing this forum: No registered users and 68 guests
