Megane II 2004 Dci Egr valve Where is it?
scottdmc88
Currently Drives:: 2004 Megane dci 1.5
Postby scottdmc88 » Sun Jan 15, 2012 4:28 pm
Can anybody tell me or show me where the egr valve is on a megane ii 04 dci
I have no idea where it is.
ottomanmegane
Currently Drives:: 2004 megane dci
Re: Megane II 2004 Dci Egr valve Where is it?
Postby ottomanmegane » Sun Jan 15, 2012 9:55 pm
under the bonnet there should be a big cover over engine , take that of .then look at top of engine ,over the top of engine you will see a big pipe intercooler pipe ,it drops down the front of engine . where you see the pipe on top of engine you follow it to the turbo .on that unit you will see tjhe egr valve with a wire going to it .it is held in place with i think 3 bolts very small .undo the nuts and slowely pull it out of housing it might be tight . buy yourself a new metal gasket first from dealers , you will see it all sooted up inside give it a really good clean
good luck
leighton
scottdmc88
Postby scottdmc88 » Mon Jan 16, 2012 6:09 pm
Thanks buddy
Ill try it at the weekend :-)
Users browsing this forum: No registered users and 27 guests
