car will not turn over hELP!!!!!
i fitted a new engine in my renault megane 1.6 16v and when u press the start button it will not turn over .i thought there might be a earth strap from the engine to the body if ,where is it and would this effect it starting if it wasnt fitted Help!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: car will not turn over hELP!!!!!
yes this would stop it from starting. not sure where the cable is but putting a jump lead from battery - to the engine block should be able to bypass this possability,
i presume you are still using your cars original ecu,
what is the dash doing when you try to start it and what is the immo light doing flashing like mad or on steady
