First Fault - Severe Rattle / Clunking
- ikhan
Just had my first fault - the car has suddenly developed a severe rattle and clunking from the rear on mildly uneven roads. I thought is was the exhaust but that seems ok. Haven't been able to have a look underneath though as it was dark. Could be the heat shield or perhaps a clap from the exhaust... any other ideas? Garages will be shu for the next few days and I dont fancy driving it in that state....
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Lowered 45mm (Spax)
- Ray
Re: First Fault - Severe Rattle / Clunking
usually a heat shield in the middle of the car. oddly caused by driving into a massive puddle which bends the heatshield.
- ikhan
Thanks for the reply Ray.
I've just had a quick glance under the car and I think I know what it is....
The shock absorber on the driver's side is missing it's lower mounting nut.... the guy who fitted my springs must have left this loose but prior to this, there were no clunks of any sort that would have normally had me worried enough to check.
Also, the mounting bracket for this also seems to be missing - can this be bough separately? Has any one got a diagram of the rear suspension or knwo of the part that I need to get? I don't want to be too harsh on the garage because the guy did me a favour as he doesn't actually do any mechanical work due to ill health and he's local....
TIA
TIA
Lowered 45mm (Spax)
Lowered 45mm (Spax)
- ikhan
Just had another look to make sure - and it's a good job I did
The shock absorber is fine - the bolt is hidden by the plastic cover which is missing on the passenger side
So I guess it needs to go on a ramp to see what is loose but that means waiting until Wednesday - don't want to use the car like this!
Lowered 45mm (Spax)
Lowered 45mm (Spax)
- ikhan
Back again
I was painting my calipers today so I thought I'd take a closer look when I've got each corner of the car jacked up...
Last corner (driver's side rear) felt a bit 'weird' - this was the one I initially thought had the nut missing but then saw the nut was still there. However, although the nut is there, the shock absorber is NOT attached. I couldn't get a very good look as I didn't have any axle stands to hand (not that I've ever been comfortable using them ) but I could feel that there 'hole' in the bottom mounting of the shock was hollow, i.e. missing a bush. I'm not sure if the bolt has broken or even how the shock is supposed to be fitted (big washer?) but the shock has obviously come out of it's mounting hole - hope this makes sense.
So I'm guessing I need a new bolt and a bush assuming the mounting on the shock is still intact, or will the shock need to be replaced? I did drive teh car about 5 ot 6 miles to get home, so I'm hoping the spring won't be damaged (looks ok).
Lowered 45mm (Spax)
Lowered 45mm (Spax)
