window stopped working
Posted: Mon Dec 12, 2011 8:54 pm
by silky1525
the passanger window on my 54 reg cc has stopped working , it still goes down using the centre switch for when you want the roof down but doesnt work on the door switches , thinking bad conection or snapped wire , any ideas how to fix , ???
Re: window stopped working
Posted: Mon Dec 12, 2011 9:44 pm
by Rapidshed
just pull the actual unit out the door and you'll prob find the wires just come off the switch sometimes there's a flimsy plastic bit that brakes, failing that trace the wire, but if the actual window is working via the centre witch your pretty safe to assume the door switch wire, i actually have same issue with my 5 door rear window, just never remember to pull until out to fix.
Posted: Mon Dec 12, 2011 9:49 pm
by davelowe
When you say it goes down, does it also come back up (via the centre console switch)? If not, the regulator might be to blame. This is a different kettle of fish.
If a wire has broken, I would venture a guess that it will be around the door hinge 'boot'. This area gets the most mechanical stress with the door being opened and closed repeatedly.
The more information, the more help.
Posted: Mon Dec 12, 2011 10:25 pm
by silky1525
davelowe wrote:When you say it goes down, does it also come back up (via the centre console switch)? If not, the regulator might be to blame. This is a different kettle of fish.
the window goes down and back up using the centre switch ,
Posted: Sun May 06, 2012 8:34 pm
by silky1525
if the pas door switch was to blame would that stop the drivers side switch from operating the passanger window
Posted: Sat May 12, 2012 5:35 pm
by bobbson
Have you had this fixed?
I have the same problem with my front driver side window in my 5 door Sport Tourer. The switch works for down but not up.
Posted: Sun May 13, 2012 7:22 pm
by silky1525
bobbson wrote:Have you had this fixed?
no not yet ,
Posted: Mon May 14, 2012 7:24 am
by viv
This may not be relevant to your window problem but as someone who has had 5 window mechanisms (x2 drivers side window) replaced so far in the life of my 53 Megane Dynamic did you know that Renault is making a contribution! towards the replacement of window mechanisms for cars that are 7 years or under and under 100,000 miles. Doesn't help me but spread the word as unless owners take cars to a Renault garage or ring Renault they won't know about it.
