hi guys steering on my 03 dci 120 seems a bit odd, at slow speeds it seems a little vauge, and at higher speeds a bit knotchy, is it electrically assisted in some way or are there any known faults?
need to get it in for allignment/tracking as seems to be a bit all over the shop pulling left and right sometimes then other times spot on, tyres are all good so i'm lost, i could understand one side pulling but not both.
steering? electric assisted?
Re: steering? electric assisted?
the steering on these is electric and is speed sensertive,
i would check the front suspention for play in lower arm and track rod ends as this is most likely where your problem is and paying for tracking to be adjusted with worn out parts is just wasteing money
Users browsing this forum: Google [Bot] and 44 guests
