MOT failed
Vintyd
Currently Drives:: Megane II 1.4 16v
MOT failed
Postby Vintyd » Sat Nov 05, 2011 12:09 pm
Misses brought her car for MOT failed on Suspension joint : excessive movement on the NSF, car is 2005 1.4
I jacked up the passenger side and there is a bit of movement from left to right, guy at the MOT center said it was most likely the ball joint. I replaced the suspension arm this morning, what a job bit of a pain with the half subframe in the way! Now thing is it hasn't made a difference, drop link and track rod end seem fine could it possibly be the top mounts?
Vintyd
Re: MOT failed
Postby Vintyd » Sat Nov 05, 2011 12:53 pm
Did a search and found the problem I'm having could be the inner track rod/axial rod so gonna go and have a look now will let you know how I get on.
tomalamix
Re: MOT failed
Postby tomalamix » Sun Nov 06, 2011 9:21 pm
yep, the problem was not the suspension arm but the rod end or axial rod, its attached to the steering box, you can miss it. if by hand you feel a "click" on your hand youve found your problem.
good luck
Vintyd
Re: MOT failed
Postby Vintyd » Mon Nov 07, 2011 9:57 am
Replaced the axial rod and TRE yesterday was handy enough thought it was gonna be a nightmare but managed to get the vice grips on, a few taps and off it came :grin Luckily enough it looks like Renault didn't have any thread lock on it! It didn't feel that bad but when moving side to side there was the exact feeling you got with the wheel a slight notch side to side. Tested after fitting everything and as good as new just need the alignment set 8-)
